Navionics+ - Raymarine Dragonfly 5PRO
racOOn
Prispevkov: 223
Pridružen: Pe Dec 07, 2007 01:08
OdgovorNapisal/-a racOOn » Po Maj 28, 2018 13:42
Pozdravljeni!
Ima mogoče kdo Navionics+, ki bi pasal tudi na Raymarine Dragonfly 5 pro?
Kupil čisto frišnega, pa pride samo s Silver kartico - mapa ni z vsemi podatki.
Za uslugo se oddolžim!
erneesto
Prispevkov: 178
Pridružen: Po Jul 08, 2013 23:22
Re: Navionics+ - Raymarine Dragonfly 5PRO
OdgovorNapisal/-a erneesto » Po Maj 28, 2018 22:25
Kje si nabavil...cena? Moram si nekaj omislit.
racOOn
Prispevkov: 223
OdgovorNapisal/-a racOOn » To Maj 29, 2018 08:07
erneesto napisal/-a:Kje si nabavil...cena? Moram si nekaj omislit.
Nabavljam pri našem članu Nikoli Teslu - Harpoon d.o.o. v Trzinu. Prej sem imel Lowrance Mark 5x PRO. Ga prodajam, če te zanima.
Drugače pa je DragonFly že čisto druga pesem... Kolko dnarja, tolko muzike.
Lowrance Mark 5x PRO:
Product Information
They’re not going to get away this time. Give yourself an advantage over the fish you are trying to catch with the Lowrance Mark-5x Fishfinder that gives you a technological edge over the elusive prize. Finding your dinner has never been so easy with a newly optimized Automatic Mode that allows you to turn on your unit and get to fishing. For even greater accuracy, an Advanced User Mode allows you to make adjustments based on current water conditions. The Lowrance Mark-5x Pro Fishfinder is a fisherman’s best friend, a high-speed dual-frequency Skimmer transducer that provides you with the intel needed to determine what’s hiding beneath the deep blue sea. With 83/200kHz sonar coverage and a built-in water temperature, locating fish has never been easier, regardless of what fishing accessories you may have used in the past. In fact, you’re even able to scroll through the sonar history and track locations that you may want to visit again. You can zoom in to study details that may provide you with more key information for a current or future fishing expedition. All of this information is provided on a bright-white LED screen and keypad backlight adjustments make it simple to enforce any necessary display changes due to the time of day or night. The 5-inch display has 480x480 pixel resolution, and the 16-level Gray Scale Supertwist Monochrome ensures the utmost visibility, even in direct sunlight. This screen displays with vivid detail and clarity all of the information, such as target viewing and separation, you could possibly need when surveying a particular area of water. With such a detailed display and so much advantageous information, the fish don’t stand a chance. It doesn’t matter where they’re hiding because the Lowrance Mark-5x Pro Fishfinder can search depths of up to 1,000 feet and it operates with a Dual-Frequency 83/200 kHz Skimmer Transom-Mount Transducer that can cast a 120-degree net of sonar coverage. As a result, you can cover a larger area in just one pass and receive intel on targets that are remaining in the area longer through more detailed readings. Of course, you can also always use the TrackBack feature to scroll through several pages of your fishfinder history. Something that can do so much sounds like it’d be hard to install, but that couldn’t be further from the truth. A convenient case/mounting design makes the entire process of setting up incredibly simple so you can get out on the water and catch some fish. This unit is designed to fit in the same cut-out used for previous 5” Lowrance models, with a new one-handed tilt/swivel view adjustment that helps keep the installation process painless. The Mark-5x Fishfinder can be used in freshwater or saltwater, and its sealed, waterproof design keeps it from being harmed by the elements. Next time you’re out on the boat, don’t play the same old guessing game you’ve been playing for years. Follow the fish and use the transducer and sonar technology to determine your best bet when dropping your line. Stop relying on fishing accessories that don’t do half of what is accomplished by the Lowrance Fishfinder that can search the depth of any ocean, lake or other body of water and lead you to where the fish are biting.
racOOn
Prispevkov: 223
OdgovorNapisal/-a racOOn » To Maj 29, 2018 08:13
Za ceno pa najbolje, da pokličeš NT. Moj model je bil čez 500€...
racOOn
Prispevkov: 223
OdgovorNapisal/-a racOOn » Če Maj 31, 2018 09:54
Kaj res nihče ne uporablja Navionics+ na Raymarine ploterju?
zalesjak
Prispevkov: 171
Kraj: Štanjel
OdgovorNapisal/-a zalesjak » Pe Jun 01, 2018 20:05
Pozdravljen,
jaz sem kartico Navionics Silver, ki je bila priložena Dragonflyju 6 nadgradil v Navionics + preko neta online iz Navionicsove spletne strani.
Bila je neka akcija -50%, če se dobro spomnim cca 120€.
LPZ
racOOn
Prispevkov: 223
OdgovorNapisal/-a racOOn » So Jun 02, 2018 10:13
zalesjak napisal/-a:Pozdravljen,
LPZ
Poznam. Vem. Ugodno. Ni takšen strošek. To bom, izgleda, tudi jaz naredil. Sem pa vseeno vprašal tukaj, če se da kartico kopirati, da prišparam kakšen € za bencin.
Če bi lahko laufalo na dveh, sem pripravljen dati polovico.
andrejv
Prispevkov: 762
Kraj: Ljubljana, Koper
OdgovorNapisal/-a andrejv » So Jun 02, 2018 18:48
racOOn napisal/-a: Sem pa vseeno vprašal tukaj, če se da kartico kopirati, da prišparam kakšen € za bencin.
Na kratko - ne da se. Je tako narejeno, da pri kopiranju uničiš kartico. Nisem sicer poskušal, ampak sem o tem bral na raznih tujih straneh.
Morda bi se jo dalo skopirati na zelo nizkem sistemskem nivojuu, ampak tako daleč se nisem poglabljal.
Skratka, uporabi upgrade s popustom.
andrejv
Prispevkov: 762
OdgovorNapisal/-a andrejv » So Jun 02, 2018 19:00
andrejv napisal/-a:
racOOn
Prispevkov: 223
OdgovorNapisal/-a racOOn » Po Jun 04, 2018 09:29
andrejv napisal/-a:
Andrej, hvala za popolno informacijo! Direktna, kratka in jedrnata. Med pričakovanimi odgovori, je bil tudi tvoj. Zdaj vsaj vem, da ni druge rešitve...
OdgovorNapisal/-a Daki » Po Jun 04, 2018 22:07
andrejv napisal/-a:Na kratko - ne da se. Je tako narejeno, da pri kopiranju uničiš kartico. Nisem sicer poskušal, ampak sem o tem bral na raznih tujih straneh.
Tudi sam sem poskusil, pa se res ne da. Kartice pa nisem uničil pri kopiranju.
andrejv
Prispevkov: 762
OdgovorNapisal/-a andrejv » To Jun 05, 2018 13:52
racOOn napisal/-a:
Če te zanima več, je precej govora o tem na raznih foruimih. Kar se uničenja kartice tiče, to velja samo za starejše CF kartice, ne za SD.
http://www.ybw.com/forums/showthread.ph ... bec2f59aba
OdgovorNapisal/-a admin » To Jun 05, 2018 21:54
Zagotovo je to dobro zaščiteno z nekim ključem, mogoče kakimi "bad-sektorji" na kartici in podobno. Za Navionics ne poznam, vendar verjamem, da je dobro zaščiteno. Vseeno pa se zagotovo to zaščito lahko precej elegantno obide, če nekdo obvlada IT in ne samo da zna narediti format diska in na novo naložiti Windows... :D :evil:
Morate pa vedeti da so to avtorske pravice, spoštujmo to! Kupimo original in ne ponaredek. Realno je tudi to, da bo vsem ponaredkom odklenkalo v naslednjih letih! Vsi moderni ploterji imajo danes wi-fi, povezavo na telefon, itd. Čim to imajo, zagotovo pošljejo ven tudi serijsko številko in tako proizvajalec natančno ve kdo ima crack. Potem ti bo pa enkrat samo poslal alarm na ekran, da imaš crack in da kupi takoj ali pa ti polje odvetnika.
Danes deluje na tak način pri vseh malo bolj resnih programih. Moje mnenje je, da bomo v naslednjih letih, mogoče desetletju te zaščite povsem izgubili. Vse boš lahko naložil, potem pa moral plačati. Če ne boš, bodo itak vedeli, saj danes brez povezave v splet še hladilnik več ne obstaja!
