Izvenkrmni motorji Parsun Sea King
Wisdom
Prispevkov: 569
OdgovorNapisal/-a Wisdom » Pe Avg 03, 2018 11:14
Hoj!
Parsun Sea King 4T v rangu 40 KM. Pa še EFI povrh. Cena tudi ni visoka, po mojem mnenju eden cenejših motorjev v tem rangu. Pri nas jih zastopnik (še) nima v ponudbi.
Vir: http://www.veetehnika.ee/products/mooto ... i/1541925/
Še nekaj podatkov, žal v angleščini:
SeaKing F40FWL-T EFI
SeaKing 40hp outboard motor is simply the best value for quality mid-outboard in it's class. SeaKing again provides many of the features of a much more expensive outboard motor. Durable, reliable, fuel efficient, quiet superior performance.
SeaKing F40FWL-T features:
The most popular outboards on the water because they deliver what every boater wants – no-worry reliability and outstanding performance
Advanced power, commendable performance
PARSUN 40hp four stroke have long led the pack in clean, quiet, fuel-efficient outboard
We combined innovative engineering with advanced reliability and features to make our outboards run clean, stay quiet, and deliver smooth, responsive performance - all while cutting your fuel and maintenance costs
Reliablility, easy Starts. smooth Running and superior Corrosion Protection
Performance, quicker is Better, large-displacement dual overhead cam increases low-end power
Easy Shifting, The precision engineered shift system, delivers smooth, positive shifting for an improved driving experience
Fuel effeciency, clean power, PARSUN 40hp outboard motors are designed to run clean, helping to protect the environment for generations to come
Model F40FWS-T EFI
Max output 40hp/ 29,4kW
Engine type four stroke, 3 sylinders, OHC
Displacement 747cm³
Full throttle RPM range 5500~6000
Weight 95kg
Rec transom height L (508mm)
Gear shift forward / neutral / reverse
Starting system electric + manual
Steering system remote control
Trimm and tilt system electric
Alternator output 12V DC (20A)
Kütusepaak 24l
Max fuel consumption 13,8L / h
Warranty 2 years
Price
4821.00 EUR
trenutna 4200.00 EUR
Vir:http://www.kalastuspood.ee/moodul.php?moodul=eCommerce&Komponent=eShop&product_id=2954&f=productPublicDetailView
UrbanBatic
Prispevkov: 318
Kraj: Waj
Re: Izvenkrmni motorji Parsun Sea King
OdgovorNapisal/-a UrbanBatic » Pe Avg 03, 2018 11:48
Nekje na forumu sem že bral, da so Parsun 4-taktniki delani 'po licenci' Yamahe.
Če obiščemo spletno stran za rezervne dele v EU ti piše zraven modela, da je mnogo rezervnih delov kompatibilnih z rezervnimi deli Yamahe F30-F40 (in vice versa). https://parsun.eu/outboard/spare%20parts/
Glede na tvoje specifikacije in specifikacije Yamahe F30-F40 iz KMC bi to moralo kar biti res. https://www.kmc.si/si/izvenkrmni-motor-yamaha-f40-akcija-i25917.shtml#technical-tab
Kateri deli niso kompitabilni (razen plastik) je pa sedaj vprašanje, ki ti da najverjetneje tudi odgovor na morebitno vprašljivost kvalitete. Nekje so morali šparat. :)
Mogoče se bo kdo, ki ve več o temu, razpisal in nas neznanil z več inforamcijami.
OdgovorNapisal/-a Daki » Pe Avg 03, 2018 12:04
Ja Parsun je kitajska kopija Yamahe, tako da deli kar pašejo. Se pa da dobiti tudi Parsun dele v Ljubljani (Maher). So cenejši. Sem že jemal tam.
Prispevkov: 6557
OdgovorNapisal/-a AEgir » So Avg 04, 2018 13:52
Že parsun je pogreb to je pa še njihov spin-off. Jao :)
Prispevkov: 4832
OdgovorNapisal/-a kocka » So Avg 04, 2018 20:52
V neurju ko ti crkne, ga navežeš namesto sidra, pa še to mu ne bi zaupal. Nekako bolj zaupam priznanim firmam ali pa starim 2T, kot kitajskim EFI.
