outboard 557 hp
Novosti, ki se pojavljajo na področju motornih plovil in jadrnic
kiaman
Prispevkov: 111
Pridružen: So Apr 04, 2009 19:50
Kraj: ljubljana
outboard 557 hp
OdgovorNapisal/-a kiaman » Sr Maj 04, 2011 17:59
a ste videl to zverino, ki jo je seven marine predstavil v miamiju!
Model 557
Rated Power 557 hp @ 5400 RPM
Rated Torque 550 lb-ft (745Nm)
Engine Construction All aluminum
Engine Configuration 90 degree V8
Displacement 6162cc (376ci)
Bore x Stroke 103.25 x 92mm
Compression Ratio 9.1:1
Induction System 1.9 L TVS supercharged and intercooled
Cooling System Closed loop
Fuel System Returnless center feed Multi-Point Injection (MPI) with stainless steel fuel rail
Maximum Speed 5500 RPM
Steering Integrated hydraulic power steering
Lubrication System Wet sump
Oil Capacity 8 qt
Ignition 8 coil digital ignition
Alternator 12V 150A
Trim Power trim and tilt
Gear Shift Electronically controlled wet clutch
Exhaust Stainless manifolds with dual overboard exhaust
Shaft Length 20 in (508 mm)
25 in (635mm)
30 in (762mm)
Rotation CW and CCW
Trim and Tilt Range -5 degrees to 67 degrees
Shallow Water Trim Range 15 degrees
Recommended Fuel 89 octane compatible; 92 octane recommended for maximum performance under all conditions
Gear Ratio 1.70, 1.75, 1.85
Dry Weight 1000 Lb (454 Kg)
All specifications are subject to change.
če ga naročite, vam ga pobarvajo v katerokoli barvo!
live long and in prosper
Prispevkov: 5982
OdgovorNapisal/-a pajer1 » Sr Maj 04, 2011 22:38
Joj si me zafrknil!
Ravno jutri ga hotel naročit in to v črni barvi.
Zdaj pa ne odstopam od naročila, ker ne bo več presenečenje.
Uf, res je huda mašina.
Spet nove igrače za velike fante!
Prispevkov: 3977
OdgovorNapisal/-a janadino » Če Maj 05, 2011 07:24
Videti je kot iz vesolja. :lol:
cibro
Prispevkov: 5004
OdgovorNapisal/-a cibro » Če Maj 05, 2011 13:49
Kakšna krma je to da zdrži 2 takšna to je skoran tona teže
http://www.seven-marine.com/motors/gallery/
goahead
Prispevkov: 1488
OdgovorNapisal/-a goahead » Če Maj 05, 2011 14:24
Evo pa so prišli določeni Italiani do pravega motorja za svoje gumone! :lol:
kiaman
Prispevkov: 111
Kraj: ljubljana
OdgovorNapisal/-a kiaman » Če Maj 05, 2011 16:27
joj pajer1, če bi pa to vedel, bi pa še kakšen dan počakal... samo mislim, da mi je tvoja barka čist hvaležna, ker ji ne boš take zverine obesil na krmo :P
sploh zdaj k si jo tako popedenal za novo sezono
lp!
OdgovorNapisal/-a kocka » Po Jun 06, 2011 13:59
Cibro, kakšna ? 3cm vezana plata pa 3plasti mate in rovinga, mora držat.
cibro
Prispevkov: 5004
OdgovorNapisal/-a cibro » To Jun 07, 2011 09:23
A mene je bilo strah ko sem 9cm vezano dal za 60hp mašino :shock:
